Discussion topic: Sky mimi box not connecting
This message was authored by: Archie1208
When installed at first it work ok. Then it's stopped working. It's connected to the Wi-Fi but not the sky q box
Re: Sky mimi box not connecting
@Archie1208 Have you tried rebooting your main Q box ie
then
reboot the mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Archie1208
Yes I've tried everything. Full reboot turned the main sky q box off for over 30 seconds. Rebooted the Wi-Fi, reset the sky mini box. I've literally exhausted everything
Can someone please advice me as this is a brand new mini box which isn't working. I have looked up what to do and followed the instructions several times. Rebooted everything several times including Wi-Fi and both main sky q box and mini box. Still not working. I feel it will require a technical engineer to resolve the situation.
Hi @Archie1208
Then you need to contact Sky directly for an Engineer visit.
This message was authored by: minniebarker
My mimi box not working
