Discussion topic: Sky max recording
This message was authored by: John173
Sky max recording
My box alllos me to watch Sky max but cant download league of their own in SD (I dont have HD)
Re: Sky max recording
Are you sure you are trying to download the SD version as it might default to the HD one.
Press Home on your Sky Q remote and select Settings, then Setup. Select Preferences, then 'On Demand default download format', and choose SD.
Avatar for John173
I have 100% selected SD.
I did follpw your tip on changing the preference moving fprward though. So thank you @caesarome
Any other thoughts?
