21 Dec 2023 09:25 AM
Hi
over a week when watching tv the sky box freezes. Says technical fault. It will not switch off via remote control and have to re plug to re boot
21 Dec 2023 09:37 AM
@Kiran7 wrote:
Hi
Hi @Kiran7
23 Dec 2023 07:05 AM
Thank you
