9
This discussion topic has been answered Discussion topic: Sky f1 channel
This message was authored by: jaswan
Sky f1 channel
Anyone else got a problem with sky q F1 channel not working , but all other channels fine 🤦🏻‍♂️
This message was authored by: Mark39 Answer
Re: Sky f1 channel
Re: Sky f1 channel
Not working how? 'No satellite signal' message?
Avatar for jaswan
Re: Sky f1 channel
Obviously, as all other channels are working
Re: Sky f1 channel
@jaswan
You hadn't said that at the start. If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
Avatar for jaswan
Re: Sky f1 channel
I did say that All other channels fine,
thanks for your positive response
Re: Sky f1 channel
@jaswan What may seem obvious to you is not obvious to us - there can be different issues and a few different symptons and messages
We don't even know which system you have - SKY HD , SKY Q, Glass or Stream ?
I have SKY Q & both Hd & UHD working perfectly OK
Re: Sky f1 channel
Avatar for jaswan
Re: Sky f1 channel
All sorted thanks 👍
Avatar for jaswan
Re: Sky f1 channel
Read the thread before commenting
sky q 👍
This message was authored by: Kelsingra
Re: Sky f1 channel
Posted by a Sky employee
Hi all,
I would like to just remind everyone to please be nice to each other when posting on the forum. We are here to help each other 🙂
Thank you for getting involved in our Sky Community. 🙂
Fanni
Community Moderator
