Discussion topic: Sky equipment doesn’t work together!
This message was authored by: Schilvers
Fed up as sky Q & mini boxes constantly not working - no WiFi all the time! Sky WiFi not worth it if it can't work with its own equipment!!! NOT HAPPY AT ALL!
Re: Sky equipment doesn’t work together!
Do you have a question or want to give some detail?
Hi @Schilvers Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
