Discussion topic: Sky equipment doesn’t work together!
Message posted on 27 Jul 2025 10:21 PM
Fed up as sky Q & mini boxes constantly not working - no WiFi all the time! Sky WiFi not worth it if it can't work with its own equipment!!! NOT HAPPY AT ALL!
Message posted on 27 Jul 2025 10:31 PM - last edited: 27 Jul 2025 10:31 PM
Re: Sky equipment doesn’t work together!
Do you have a question or want to give some detail?
Message posted on 28 Jul 2025 07:38 AM
Hi @Schilvers Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, do the same with any Mini boxes?
