Discussion topic: Sky dish mounted onto window sill
Message posted on 21 Jun 2025 12:42 PM
Do you think that my sky dish clamped to my outdoor, brick windowsill will be safe? I will attach a rubber pad and have a sturdy G-clamp clamping down to the rubber pad (https://www.amazon.co.uk/gp/product/B000LFVHH4/ref=ox_sc_saved_image_5?smid=A3FC837E69UD1Z&th=1). I will then attach a 3-foot swan-neck pole to it, and the sky dish will be mounted at the top (zone 1, MK4). Also, I will have metal wire wrapped around the top of the pole to make sure the pole doesn't lean. Do you think this will be a good solution for no-drilling for a flat on the second floor trying to get a sky dish?
Message posted on 21 Jun 2025 12:58 PM
Re: Sky dish mounted onto window sill
@JoshUmney A dish needs to be properly installed on a suitable surface, a G-Clamp won't be sufficient to hold such a weight. In additon what happens if it fails and falls on someone, you'll be leaving yourself open to prosecution if a falling dish injures someone, or worse.
Best advise is to get it installed correctly & professionally
Message posted on 21 Jun 2025 01:08 PM
Agree. No. It will also look hideous.
Probably better to get Sky Stream
Message posted on 21 Jun 2025 01:20 PM
Sky engineers won't work on any issues that come about on a D.I.Y. placed dish. They have very strict health and safety regulations, even more so at height.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 25 Jun 2025 05:28 PM
Sky dish attached to a downpipe
Do you think that my sky dish attached to my outdoor, plastic downpipe for my gutter will be safe to install a sky dish too with my equipment and steps? I will attach a rubber pad and have a sturdy u-bolt clamping down to the rubber pad (https://amzn.eu/d/6L2XUZ4). I will then attach the sky dish (zone 1, MK4). Do you think this will be a good solution for no-drilling for a rented flat on the second floor trying to get a sky dish?
Message posted on 25 Jun 2025 05:30 PM
Re: Sky dish attached to a downpipe
@JoshUmney I think you'd be better using Stream or Glass for your situation.
Message posted on 25 Jun 2025 05:37 PM - last edited: 25 Jun 2025 05:39 PM
You asked a very similar question a few days ago (posts merged). Sky engineers won't work on a DIY set up.
Message posted on 25 Jun 2025 05:39 PM
hi @JoshUmney
Sorry to be the bearer of bad news but I fear you are wasting your time trying to come up with inventive ideas on how to get a dish even if I admire your ingenuity
SKY will not connect to any dishes they do not install and can successfully access.
I know this is likely to be very frustrating for you
Message posted on 25 Jun 2025 07:46 PM
Mate, just get Stream for now. We'll all be on it in about 5 years anyway.
Message posted on 25 Jun 2025 08:11 PM - last edited: 25 Jun 2025 08:13 PM
Perhaps contemplate the wind loading of a 60mph gust on an area the size of a satellite dish, and the relative load-bearing capacity of a brittle plastic tube vs a bolted metal bracket...
