Discussion topic: Sky dish loose
Message posted on 24 Nov 2024 08:13 AM
Sky dish loose
Hi my sky dish is loose and making right rattling noise. It is still working but can't sleep as close to mine and neighbours rooms. Only had it since August. Will sky fix it?
Message posted on 24 Nov 2024 08:16 AM - last edited: 24 Nov 2024 08:18 AM
Re: Sky dish loose
Technically the ownership of the dish transfers to you on installation but give Sky a call and they will very likely come out to you.
From a Sky Talk landline or a Sky mobile dial 150 to call Sky (free).
Alternatively use this link:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and a dedicated 03** UK number is displayed.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a dedicated 0818 ROI number.
(The forum doesn’t allow us to type the numbers in full).
Similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
