Discussion topic: Sky disc
Message posted on 14 Apr 2023 06:54 AM
Sky disc
Thinking of moving to sky glass and wondered what happened to my sky disc? Will someone remove it?
Message posted on 14 Apr 2023 06:56 AM
Moving to sky glass
also I don't understand re ownership of the tv ... if it's only £10 upfront when do we own the tv? Does this mean once the tv is paid off the subscription monthly payment will go down?
Message posted on 14 Apr 2023 06:59 AM
Re: Moving to sky glass
Sky will not remove the satellite dish. That is your property. It you want it removing you will have to do it yourself or you could get a local handyman to do it for you.
Message posted on 14 Apr 2023 07:03 AM
Re: Sky disc
hi @Amy1333
SKY don't remove dishes - it is yours to do as you wish and you can remove it yourself or get a handyman to remove it. It doesn't need to be a Satellite specialist.
We do, however, recommend that you do not this until you are sure you won't return to SKY Q as some people find Glass/Stream not quite the same for them
Message posted on 14 Apr 2023 07:42 AM
@Amy1333 wrote:Thinking of moving to sky glass and wondered what happened to my sky disc? Will someone remove it?
You 'own' the TV as soon as you enter into a credit agreement to purchase it. The monthly cost of the TV is in addition to the streaming channel subscription cost, so once you have paid for the TV you only need to pay for the streaming subscription. Depending on your contract you can cancel the streaming subscription too & just use Glass as a big dumb monitor with some Sky-controlled apps on it.
Make sure you understand how Glass works - it's a very different type of service to Sky+ or Sky Q.
Message posted on 25 Apr 2023 04:19 AM
Re: Sky disc
Or if you left the dish where it is can be used for Freesat TV.Saves paying for another dish to be put up.
Sky Glass 65 inch
Sky Glass 55 inch
Whole Home,Cinema and Sports
Sky Live,
Sky Broadband Ultrafast,
Sky Broadband HUB 4,
Sky Mobile.
Sky Live
Message posted on 25 Apr 2023 07:03 AM
Re: Sky disc
@paulw49 wrote:Or if you left the dish where it is can be used for Freesat TV.Saves paying for another dish to be put up.
If you want to use the dish for freesat you either need the 4K freesat box or have the LNB in the dish changed for one that will work with the other freesat boxes.
