Discussion topic: Sky has error MR 106
This message was authored by: Kate+Whitelock
  • My mini box is showing a error MR 106
Avatar for Kate+Whitelock
Level 0 icon
Re: Sky has error MR 106
Hi @Kate+Whitelock
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
