Discussion topic: Sky cannot connect to sky broadband
This message was authored by Maddazza This message was authored by: Maddazza
My sky q box has all.of a sudden decded not to connect to sky broadband I've tried reset on both devices putting the WiFi password in manually also pressing wps and nothing
Re: Sky cannot connect to sky broadband
Hi @Maddazza
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
