Discussion topic: Sky broadband buffering
Message posted on 14 Jun 2024 10:00 PM
Message posted on 15 Jun 2024 06:20 AM
Re: Sky broadband buffering
As it is only the Sky Q box that is buffering then one needs to confirm the wireless signal is strong enough for it to work correctly. If it keeps buffering then contact Sky for them to fix the issue.
Message posted on 15 Jun 2024 11:48 AM
Message posted on 15 Jun 2024 11:55 AM
Is the WiFi on the Q box definitely switched off?
Message posted on 15 Jun 2024 11:56 AM
When the Sky Q box is wired to the router then one can get LAN broadcast storm issues which is a design fault with Sky Q, it would be good to establish whether you have throughput issues and a speed test should be done on an alternative wired/wireless device to establish that the broadband is fine incoming. A post of the router stats would be useful as would historical data from the Sky App confirming that one is getting the speed advertised and guaranteed by Sky for your broadband.
Message posted on 15 Jun 2024 12:49 PM
Been in touch with sky.
Diagnosed a faulty Q box
New one coming Mon
Thanks for all the assistance
