Discussion topic: Sky box
Message posted on 25 Jul 2024 03:28 PM
Sky box
Hi my sky box keeps randomly turning off. Can I get the smaller sky box that is now available
Message posted on 25 Jul 2024 03:35 PM
Re: Sky box
There is no smaller Q device - perhaps you mean switching to Stream but is a quite different product (no recording).
You'll have to call Sky to discuss your options or replacement box.
Re: Sky box
There is no smaller box to replace the main Q box.
The smaller boxes are mini boxes where you need a monthly Multiscreen subscription to use additional Televisions.
There is a Sky Stream system which has smaller boxes and works by Streaming direct from the internet and does not need a Satellite dish.
Regarding your Q issue
