Discussion topic: Regularly lose number of channels from menu. Channels change without using remote device..
This message was authored by: GAZAFC
Message posted on 25 Jul 2024 02:42 PM
Find out more
Message posted on 25 Jul 2024 02:48 PM
Re: Regularly lose number of channels from menu. Channels change without using remote device..
For the losing channels in the epg, reboot your router, then try reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
