Discussion topic: Sky q
Message posted on 25 Jul 2024 03:46 PM
Sky q
I can't get my hub to work, the light in the bottom right stays orange, it doesn't go green. I have changed the batteries in the remote
Message posted on 25 Jul 2024 03:48 PM
Re: Sky q
Hi @Ekva2
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
