Discussion topic: I can not find any of my recordings on my Sky Q box
Message posted on 08 Jul 2024 06:46 PM
I have tried to go onto my recordings and it is not showing any recordings and it is just saying please wait with a loading circle. When I go to down load it is saying technical issue but I have reset everything and tried again twice. I have no access to anything that has been downloaded or purchase the whole of the recording section can not be accessed
Message posted on 08 Jul 2024 07:10 PM
Re: I can not find any of my recordings on my Sky Q box
Hi @Tiffanyd123
Have you tried rebooting your Q box?
Failing this and if you cannot make new recordings then you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
