Discussion topic: Sky box not working properly
This message was authored by: Johnscott10
Message posted on 21 Apr 2024 11:57 AM
The box powers up only green light and the sky info plays on the tv
This message was authored by: ThePope27
Message posted on 21 Apr 2024 04:30 PM
Re: Sky box not working properly
Hi @Johnscott10
If the remote isn't responding, try pressing and holding 7+9 until it flashes 4 times which will fully reset the remote, then make sure there is a line of sight between the sky q box and the remote and hold 1+3, you should see another menu about controling your tv, you can either do this or skip, then your remote should now be re paired with the q box
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
