This discussion topic has been answered Discussion topic: Remor note connecting to box properly
Message posted on 02 May 2024 11:15 AM
Remote not connecting properly to box, changed remote issue still the same
Message posted on 02 May 2024 11:20 AM
Hi @Farmer1960
First reboot your Q box.
Hi @Farmer1960
Message posted on 02 May 2024 12:02 PM
Re: Remor note connecting to box properly
Thanks very much it has worked.
