This discussion topic has been answered Discussion topic: Sky box not working properly
Message posted on 08 Apr 2024 11:09 AM
Hi my skbox won't let me watch recordings or download on catch up it won't pause tv channels either the only thing I can do is watch tv & turn up & down the volume. I've tried turning on & off box a few times but still mot working it says problem with hard disk when I try to pause & then it says technical problem when I dry to Dowland using catch up it won't go into recordings.
Message posted on 08 Apr 2024 11:29 AM
Hi @TILLY691
Please attempt a Hard Drive Reset
To access the hidden menu, press the Home button and then navigate down to the Settings option without selecting it. Once Settings is highlighted, press 0 0 1 and then Select. Go down to Reset and Perform the Reset Hard Drive, pls note you will lose all your recordings,
Failing this try a Factory Reset which will Remove all Recordings and Settings
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Hi @TILLY691
Message posted on 08 Apr 2024 11:41 AM
Re: Sky box not working properly
Thank you @ThePope27 this worked but as you said it cancelled all my recordings but Hopefully can get them all bk again on catch up .
Message posted on 08 Apr 2024 11:51 AM
Yeah it's not ideal loosing all your recordings, but its better now than years ago when you didnt have catch up/VOD services like netflix etc 🤣
Message posted on 27 Apr 2024 11:26 AM
The box is saying software issues, no point doing hardware resets we have done these before, works for a while then back to problems.
We need a new box!
Message posted on 17 May 2024 01:49 PM
Q box not working properly
Message posted on 22 May 2024 02:54 PM
I have already spoken to your technical team and completed both a system update & hard reset, yet I was still faced with the same issues & in fact now, the box will not allow me to watch any shows or recordings at all.
