6
Discussion topic: Sky box not working properly
This message was authored by TILLY691 This message was authored by: TILLY691
Hi my skbox won't let me watch recordings or download on  catch up it won't pause tv channels either the only thing I can do is watch tv & turn up & down the volume. I've tried turning on & off box a few times but still mot working it says problem with hard disk when I try to pause & then it says technical problem when I dry to Dowland using catch up it won't go into recordings.
This message was authored by ThePope27 This message was authored by: ThePope27 Answer
Re: Sky box not working properly
Hi @TILLY691
Please attempt a Hard Drive Reset
To access the hidden menu, press the Home button and then navigate down to the Settings option without selecting it. Once Settings is highlighted, press 0 0 1 and then Select. Go down to Reset and Perform the Reset Hard Drive, pls note you will lose all your recordings,
Failing this try a Factory Reset which will Remove all Recordings and Settings
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
