Discussion topic: Problem with sky box
This message was authored by: Stephen_C87
Hi, my sky box turns off on it's own,
doesn't load Netflix straight away very often. Gets to the load page then freezes.
I have to turn the whole thing off and back on for it to work (then still doesn't work sometimes)
Re: Problem with sky box
Hi @Stephen_C87
