Discussion topic: Sky box mini issues!
This message was authored by: LeeDon1
One of my sky mini boxes keeps glitching, it freezes the picture and sound often. I have tried to unplug and plug back in. I really want to avoid a full reset as my sky q box is fine
Re: Sky box mini issues!
Hi @LeeDon1
Reboot the mini as above.
Avatar for LeeDon1
Brilliant advice. The reboot of both boxes fixed it! Thanks
