Discussion topic: How do I order sky extenders
This message was authored by: Scott73
Cannot connect skyq mini box to main skyq box. I have moved it into a new part of the house and it says I need sky extenders. Can't find a sky phone number where you actually get to talk to someone.
Re: How do I order sky extenders
You'll have to battle your way past the robot to speak to someone.
You can just buy your own extender. Someone on here used a tp-link RE200 v1 (about £20)
@Beachmouse  - did you use that to connect directly between a mini and Q or are you on Sky BB and connected it to the router's wifi?
This message was authored by: Beachmouse
@Chodley My broadband providers is Virgin Business.
I connected the main Sky Q box, via Ethernet, to the TP-Link. That is then wirelessly connecting to the network.
Ah yeah it was @Gaz1 who was using it via wifi wasn't it.
Yes, I believe he was using WiFi to connect.
