Discussion topic: Sky box does not work
This message was authored by: SB89ers
New Sky Box does not turn on, new card does not work
Re: Sky box does not work
Hi @SB89ers
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
