Discussion topic: Sky q mini box not working
This message was authored by: Chris102
I have unplugged the power to it and plugged it back in but the live TV will not work. I can still use the apps and it is connected to the main box.
Re: Sky q mini box not working
Hi @Chris102
Reboot the mini as above.
