Discussion topic: Sky box dead
Message posted on 18 Sep 2023 12:59 PM
Sky box dead
Sky box won't turn on.
Message posted on 18 Sep 2023 01:07 PM
Re: Sky box dead
Try the Sky Q recovery procedure from power off as described in step 3 here;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Message posted on 18 Sep 2023 01:27 PM
Re: Sky box dead
Hi @Jottie77
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Message posted on 19 Sep 2023 01:16 PM
Re: Sky box dead
I know this is simple but have you checked that the socket is turned on? Have you tried another device in the socket to see if there's a problem with it?
Change the fuse in the plug to see if it has blown.
I don’t work for Sky.
If I have helped then please leave a like.
