Discussion topic: Sky box and remote issues
This message was authored by: paul171170
On my tv screen the recordings screen is permanently on and my remote will not allow me roll to move off this screen. I've changed batteries and I've just ordered a new remote as my existing one is very old! Does anyone know any other related issues?
Re: Sky box and remote issues
Hi @paul171170   You should be able to use Sky Go as a remote, or probably several Apps should also be available. Have you tried resetting your remote by holding down 7 & 9 until the LED flashes 4 times. Then use the remote as IR so line of sight required.
https://www.sky.com/help/articles/sky-q-remote-help
