7
This discussion topic has been answered Discussion topic: Sky box Replacement
This message was authored by: Vaz3
Sky box Replacement
Who do I contact to get a replacement box because AI response is ridiculous going round in bloody circles
Moderator Actions: Retitled to better reflect issue
Re: Sky box **bleep**ed
@Vaz3
@Daniel0210 wrote:
@Vaz3
What issue are you having with the box
If necessary Sky will probably arrange a replacement via what is known as a 'doorstep box swap' whereby a courier company (usually DPD in the UK) deliver a new box and take your pre-disconnected faulty box away so remember to remove the viewing card from the old box before it disappears into the van. Also accept the power cable the courier brings in case it's a different fitting to the one you have already.
@Vaz3
What issue are you having with the box and is it a main Sky Q box or a mini box?
Avatar for Vaz3
It's the main sky box . The Ai I spoke to went through a series of questions and said I need to get a replacement box sent out and then just to go on the my sky app to do this
@Vaz3
@Daniel0210 wrote:
@Vaz3
This message was authored by: Jean1811
Not relay an answer
internet is on tv sky recorder says there is no internet won't connect
what do I do
Re: Sky box Replacement
Do I need a new box
@Jean1811 wrote:
Not relay an answer
@Jean1811
It was the answer to the question asked by the OP.
@Jean1811 wrote:
internet is on tv sky recorder says there is no internet won't connect what do I do
Hi @Jean1811   Assuming that you mean a Sky Q box, not an old Sky+HD box?  Setting up Sky Q.
