Discussion topic: Sky blaming ee and vice versa - help!
Message posted on 15 May 2026 03:18 PM
My internet connection is good with ee, however after tv (Samsung) has been in standby does not connect back to WiFi. Sky engineer came and blamed ee connectivity and said ee have to resolve - ee gave advice (switch off) but issue remains . Any help welcome -
Message posted on 15 May 2026 03:31 PM
Re: Sky blaming ee and vice versa - help!
@Schelll is it the TV or Sky Q that's losing connection
Message posted on 16 May 2026 04:26 PM
Hi it's the tv that's dropping out connection
Message posted on 16 May 2026 04:59 PM
@Schelll If its the Samsung TV thats dropping the connection then thats nothing to do with Sky surely and would be a problem between EE and Samsung.
If it was the Sky Q box then that would be something to do with Sky
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 16 May 2026 05:03 PM
The WiFi stays connected to the tv (and shows on the Samsung settings) but on sky tv it's showing as not connected to broadband. All other devices in the house have no problem with WiFi.
Message posted on 16 May 2026 05:07 PM
@Schelll For clarification are you saying that the Sky Q box is showing as not connected on the TV screen ?
Message posted on 16 May 2026 05:32 PM
Yes sky q showing not connected, when tv settings shows it is
Message posted on 16 May 2026 06:13 PM - last edited: 16 May 2026 06:15 PM
@Schelll Have you tried a network reset through the Sky Q settings menu. Regardless of what the Samsung TV settings are saying as that will connect independently, you need to try resetting it via Sky Q.
Message posted on 16 May 2026 06:42 PM
@Schelll wrote:My internet connection is good with ee, however after tv (Samsung) has been in standby does not connect back to WiFi. Sky engineer came and blamed ee connectivity and said ee have to resolve - ee gave advice (switch off) but issue remains . Any help welcome -
If it your tv that's losing the WiFi you and Sky box still connected to WiFi you have all have all your Sky tv and many of the apps on your tv will be available on your Sky box so why not use them on there until a solution to your tv can be found.
Message posted on 16 May 2026 06:46 PM
@DaveDrizen @Schelll has already confirmed it their Sky box thats losing connection not the TV
Message posted on 16 May 2026 07:06 PM - last edited: 16 May 2026 07:19 PM
@Schelll wrote:The WiFi stays connected to the tv (and shows on the Samsung settings) but on sky tv it's showing as not connected to broadband. All other devices in the house have no problem with WiFi.
Presumably you re using your sky remote to switch both your tv and sky box in to standby, So what is realy happening is when you switch your tv to standby it also swiching your Sky Q box to standby and when you Sky box switch back out of standby it's no longer connected to the internet? If you Sky box was not gong into standby as well there is no way that just your tv going into standby would cause you to lose the internet connection on your Sky box if it was still on. There is a setting the Sky box settings to stop your sky box going into standby when your tv dose. And you will have to use your tv to put your tv ibans out of standby but leave your Sky box on, This will sort you problem to existent as you Sky box won't lose internet every time you put you tv into standby but your Sky box will still lose internet connection if you actually put you skybox into standby so a proper solution is still required.
Message posted on 16 May 2026 10:04 PM
How do I progress a network reset?
Message posted on 17 May 2026 07:43 AM
Message posted on 17 May 2026 07:45 AM
@Schelll wrote:How do I progress a network reset?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
2 Windows desktop PC's hardwired to each Deco, everything else using the Deco WiFi
