Discussion topic: Losing connection with Fritzbox.
Message posted on 29 Oct 2023 07:21 PM
Hi all, just moved to Zen internet with a Fritzbox router, the hub is in the lounge with Sky Q box less than 10 feet away, the wi fi signal is over 400 mps in speed value.I have reset the Q box over 10 times since the install, why is this happening.
Message posted on 15 Dec 2023 08:05 PM
Re: Losing connection with Fritzbox.
Hi, we changed end November and keep having same problem.
Message posted on 19 Jan 2024 05:24 PM
I've had the same issue for 6 months now, separated the Fritz box mesh channels away from the skyq mesh helped a little but still have a weekly reload of the q network . Everything else using the Fritz box works fine, just skyq complains
Message posted on 19 Jan 2024 06:55 PM
I have now gone down the router of buying a Fritzbox repeater 3000ax and used an Ethernet cable to the sky Q mini and another one from the main router to sky Q main box.
i did make sure the flat type Ethernet cables are capable of dealing with 1 gb signals and to get have not lost any signals or problems downloading shows.
these were hidden with D line mini trunking on top of skirting board.
Message posted on 24 Apr 2024 10:21 PM
I was having the same problem.
I downloaded the MyFritz! app on my phone.
I followed these steps in MyFritz! app (after connecting the FritzBox to the SkyQ box via the SkyQ remote).
Then in the MyFritz! app go to:
> Home network
> Sky Q
From the Sky Q menu select:
> Prioritize Internet Connection
The network connection has stayed connected for 48 hrs now. Previously the connection dropped after a few minutes
Message posted on 24 Aug 2024 10:04 AM
After having followed all advice above my Sky Q box still disconnects regularly from Fritz box. Also found that I need to use an Ethernet crossover cable for it to work at all. Any further help would be appreciated...
Message posted on 21 Sep 2024 01:45 PM - last edited: 21 Sep 2024 01:46 PM
No point making a new thread but I am having exactly the same problem.
I changed to Zen a few days ago and my FritzBox loses the connection at least once a day; usually more!
I live in a small flat with no Wifi signal loss so that's not the issue.
I'm sure each company will blame the other so there's probably no point contacting either. Guess I'll just try the wired connection instead. 😠
- Zen Broadband
- Sky Q 1TB box with Signature, Ultimate & Cinema
- "I'm not small, I'm fun-size"
Message posted on 21 Sep 2024 02:09 PM
If your still having trouble connecting and keeping the service up and running.
try looking in the home page of Fritzbox, under wi fi network look for sky Q box click on the pencil icon, this will give you another page.
Internet Use
Message posted on 16 May 2026 08:41 PM
Thank you. I've followed your instructions let's hope it works!!
Message posted on 17 May 2026 06:56 AM
In the end I changed my Sky equipment to a Sky Stream puck. This solved the problem of the connection dropping. Sky Stream and the FritzBox work seamlessly together.
