Discussion topic: Sky apps not working have refreshed but hasn’t worked everything else is ok
Message posted on 30 Jun 2024 02:55 PM
Apps not working everything else is ok internet connected too
have refreshed apps with 001 in settings too
Message posted on 30 Jun 2024 04:48 PM
Re: Sky apps not working have refreshed but hasn’t worked everything else is ok
@thebradleysrule2 it can take up to 24 hours for an app refresh to work but you can try
resetting the settings in the Q boxes hidden menu.
To enter the hidden menu press the home button and scroll down to settings but do not select settings.
With settings highlighted press 0 0 1 then select
Only Carry out the first Reset being Reset Settings as the others will wipe all recordings.
After the reset you will have to re-pair your remote assuming you are using a bluetooth remote by pressing 1 and 3 together on the remote
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
