Discussion topic: I can't receive a lot of channels, eg, sky sports, bbc, problem with signal, can receive others thol
This message was authored by: Little10
Can receive other channels tho, no problem, eg crime and investigation channels.
Re: I can't receive a lot of channels, eg, sky sports, bbc, problem with signal, can receive others
@Little10
A message displaying ”no signal” tends to be from your TV.
A message displaying “no satellite signal” relates to your Sky Q box, so firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check the troubleshooting in this link
If you are connected to a communal dish you’ll need to liaise with you building management company / landlord who will have their approved engineers to contact.
Note: A misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels.
