Discussion topic: Sky a mini box not working
This message was authored by: Grinch
So I can see the tv guide, I can use the apps but cannot actually watch sky in my bedroom, if you put the channel on all I get is a blue screen with no sound! I've tried turning it off at the mains and it still happens, I've checked signal and that's fine any ideas?
Re: Sky a mini box not working
Hi @Grinch
Reboot the mini as above.
This message was authored by: ChezzaD
I've tried but reconnecting and it is still not working. I need to contact you
Hi @ChezzaD   I'm afraid you can't contact us, we are just other customers. Please see Welcome below for information about this community.
