10 Jun 2024 10:16 PM
So I can see the tv guide, I can use the apps but cannot actually watch sky in my bedroom, if you put the channel on all I get is a blue screen with no sound! I've tried turning it off at the mains and it still happens, I've checked signal and that's fine any ideas?
10 Jun 2024 10:20 PM
Hi @Grinch
Reboot the mini as above.
