Discussion topic: Sky a box saying not connected to internet
Message posted on 19 Oct 2024 08:19 PM
My sky q box is saying no internet connection I have gone to settings and followed the instructions 3 times now and it hasn't worked
Message posted on 19 Oct 2024 08:24 PM
Re: Sky a box saying not connected to internet
Are you carrying out the following?
