Discussion topic: Sky a box saying not connected to internet
This message was authored by Needhelptoday This message was authored by: Needhelptoday
My sky q box is saying no internet connection I have gone to settings and followed the instructions 3 times now and it hasn't worked
Re: Sky a box saying not connected to internet
Hi @Needhelptoday
Are you carrying out the following?
