4
This discussion topic has been answered Discussion topic: Sky TV is showing Technical Fault since 1.50 pm
This message was authored by: Paul390
Postcode OL14 , lost all sky channels, just show technical fault.  Rebooting has no effect.
Re: Sky TV is showing Technical Fault since 1.50 pm
@Paul390
Try the troubleshooting on this link.
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Avatar for Paul390
edit: the box is showing the menus now but nothing will play including recordings
@Paul390
Avatar for Paul390
Thank you Daniel, that sorted it.  I never cut the power when I rebooted (just standby).
Cheers for your help, have a good day.
Just a side note to say; satellite issues are never regional/area based (other than weather related) - it's one signal from the satellite for the entire area it covers on the ground. For those carrying Sky UK & Ireland that means;
(courtesy satbeams.com)
