Discussion topic: Sky Q
Message posted on 16 Mar 2025 09:42 PM
Sky Q
I have had to factory reset my sky q box and now my remote won't work. my screen in stuck on accessibility on sky Q and I can't finish the set up because the remote won't work
Message posted on 16 Mar 2025 09:51 PM
Re: Sky Q
This message seems to have caused a bit of a quirk & needs the remote to be in IR mode but as you have reset your box you need to reset the remote also
Do a full remote reset by pressing & holdng 7 & 9 until the red led above the SKY logo button flashes 4 times
Now ensure it is pointing at the box & you should be able to dismiss the message
Then try pressing & holding 1&3 together & follow the on screen messages to re-pair & pair with the TV
