Discussion topic: Sky Q wont connect to Virgin Broadband wirelessly
Message posted on 22 Apr 2023 09:39 PM
Hi all,
This may have been answered a thousand times, but I'm not too techicial and am slightly lost on some of the answers that appear similar.
My Sky Q box just wont connect to my Virgin Media WiFi.
Absolutely nothing wrong with my WiFi. Works for PS5, Alexa, tablet etc. It's fine.
I key in the Network details on Sky Q. Seems to connect for a second then just disconnects and tell me I dont have internet connection.
Any advice would be greatly appreciated as this has been going on for a year and I'm actually fed up with Sky Q.
Message posted on 22 Apr 2023 09:40 PM
Re: Sky Q wont connect to Virgin Broadband wirelessly
Should have mentioned....I'm in Ireland
Message posted on 22 Apr 2023 10:28 PM
Very odd I personally have sky stream and it was more than happy to connect to my virgin brodband when I had it. Although when we where transitioning from virgin to bt and sky our virgin 360 tv box point blank refused to connect wirelessly to my bt hub but would accept internet via Ethernet from the same hub. I'd attempt to connect via Ethernet cable if that works maybe inveset in a powerline adapter or else contact virgin/sky
BT 500 + whole home disc
Message posted on 23 Apr 2023 07:45 PM
Are you using the wps button on the hub & on the Sky Q box to connect or manually entering the SSID & password?
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 23 Apr 2023 08:28 PM
Hi Twilight+Princess,
I choose add broadband provider, Virgin, find the relevant broadband name, enter the password. Occasionally it says connected. For a couple of seconds. Then i get the 'x' saying Sky Q not connected to broadband
Message posted on 24 Apr 2023 01:16 PM
I would try wps via the buttons. I have a Hub 3 with Virginmedia & setup was easy that way.
Message posted on 08 Oct 2023 10:15 PM
I have this exact same problem and it's driving us mad!! We have 4 rooms with sky and none work for more than a minute or two at a time. It's not the broadband as that works on everything else. Couldn't get sky broadband in the house so had to go with another carrier.
Message posted on 08 Oct 2023 10:17 PM
Did you manage to resolve this please?
Message posted on 20 Dec 2023 01:54 PM
Folks if you want to resolve this, go to your broadbandhub management, the ip address is on your router, so is the password. Once logged in to the router on your browser go to
1. advanced settings
2. Wireless
3. Guest Network
4. Enable guest Network
this will give you a sole network to use for your sky box, just reset the network and use this new one. It worked for us after months of this issue and its now stable on our main box.
Message posted on 20 Dec 2023 02:00 PM
Thanks RMCD.
I will try this.
Occasionally it will connect by just adding the network and password but it doesnt stay comnected for more than a day or so.
The WPS option previously mentioned doesnt work for me.
I've noticed that once connected it is so painfully slow to download anything anyway. Worth nothing there is nothing wrong with my boradband, its very quick.
Message posted on 09 Nov 2025 11:28 AM
I'll give this a shot too. 1 thing is 100% certain, I will NEVER use VM again. Was with BT for years previously and not as much as a second of downtime. You get what you pay for.
Message posted on 18 Dec 2025 09:45 AM
Setting up the Guest network on Virgin Media Hub 3 and getting Sky Q to connect to that worked. Anything else I tried (changing 5GHz channels on Sky Q, setting specific 2.4GHz and 5GHz channels on VM Hub 3, etc.) didn't work. It seems that if the wifi network has lots of devices connected to it, Sky Q won't reliably connect to it. The problem seems to be with the proprietary Sky Q technology, not with Virgin Media.
Message posted on 18 Dec 2025 10:01 AM
Not a fan of Sky, but I have been told that this problem is often because third party broadband providers change their end of the standards and Sky don't if only because they cannot support different providers who do their own thing.
Our solution was to connect our Skq Q boxes to a Sky router, hardwire router to Vodafone router and connect all other devices to Vodafone.
