1
This discussion topic has been answered Discussion topic: Sky Q recordings
This message was authored by: moandto
Sky Q recordings
All my recordings in Sky Q show message This programme is no longer available even the most recent recordings. Have tried resetting using Sky help pages
This is an ongoing problem
Re: Sky Q recordings
Hi @moandto
Can you make new recordings?
If not you may have a hard drive issue.
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Hi @moandto
