Discussion topic: Multi room mini box keeps losing picture on tv, but sound is staying on
Message posted on 16 Dec 2025 05:26 PM
It's happened twice now and I'm getting a bit miffed
Sky multi room mini box just lost the picture but the sound is still playing
Switched box and tv to standby,waited a few minutes and switched back on and get the Home Screen menu with sound and picture
Is the box on the way out, it's about 2 years old I think
Don't want it to happen in the middle of something good ie film or programme
Any help please
Message posted on 16 Dec 2025 05:30 PM
Re: Multi room mini box keeps losing picture on tv, but sound is staying on
Any help please
Hi @Brijane
Box age is largely irrelevant. My minis are 9 or 10 years old.
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 17 Dec 2025 05:46 AM
@Brijane EZ Pass IL wrote:It's happened twice now and I'm getting a bit miffed
Any help please
Hello @Brijane,
It’s likely a temporary glitch rather than full hardware failure — try checking HDMI connections, updating the box software, and rebooting your router. If the issue keeps repeating, contact Sky support for a replacement, since boxes around 2 years old can start showing faults.
Best Regards,
Daniel Ramos
Message posted on 18 Dec 2025 09:40 AM
Mine is doing the exact same thing. It's really annnoying. It can't be the connection as everything else is fine, like the sound. The screen just goes black. Mine has being doing it about a week and tried unplugging cables and resetting routers etc, nothing is working.
