6
This discussion topic has been answered Discussion topic: Sky Q won’t connect with Trooli Router
This message was authored by: AOB1974
I changed Broadband last April as I wanted better speeds for work.  Ever since the connection between Sky Q and the WiFi has been poor to say the least.
Why Sky and Trooli cannnot connect to figure it out is unknown but I'm likely to leave Sky soon if they don't resolve it. At all times my other devices remain connected to the router without issue.  I've had a new box, engineer out and firewalls changed with no joy.
This message was authored by: PandJ2020 Answer
Re: Sky Q won’t connect with Trooli Router
Firewall?
With a non-Sky ISP the box will only connect over 2.4GHz.  Ensure any channel steering is disabled.  Best advise is to split SSID's between 2.4 and 5GHz.
Firewall?
Avatar for AOB1974
Already done that!!!!
Avatar for AOB1974
I went out tonight, home at 2230. No connection!!
Avatar for AOB1974
  • Every other device in the house is connected and enjoying 500mb speed. Sky could not provide that and now they won't work with another broadband provider.
This message was authored by: Tomtman
I'm having the same issue.. re-connecting network works for a while and then it gets dropped again.. ugh,
This message was authored by: Kellyhop
Did you find a resolution for this? It's starting to drive me insane that it keeps dropping the connection even though every other device is working perfectly well.
