Discussion topic: SKY Q INTERMITTENT ISSUES
Message posted on 20 Oct 2025 01:17 PM
Message posted on 20 Oct 2025 01:22 PM
Re: SKY Q INTERMITTENT ISSUES
Check the HDMI lead first.
If it was a dish problem you'd get a different message. (No satellite signal)
Message posted on 20 Oct 2025 01:24 PM
@Hammerette08 wrote:
My telly keeps flickering/ turning to black screen/ coming up with messages of either "No Signal or Mode not supported. Seems to be getting progressively worse. What component is likely to be the problem? Could it be connection to the dish and if so do we need to call a Sky engineer?
First thing to try is a differential HDMI lead between Q box and Television.
Failing this try a Reset Settings in the main Q box hidden menu.
Message posted on 20 Oct 2025 01:27 PM
No signal as a message is related to your Sky Q box connection to your TV
If it's a ' no satellite signal' message that relates to your Sky Q box not connecting correctly to your dish.
Go through this link, to see if it helps:
https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-q-no-signal-no-output-message
