Discussion topic: Sky Q with WiFi Max
This message was authored by: Shanzo1
Sky Q with WiFi Max
I have Sky Q and have recently renewed my contract. During the renewal I was offered WiFi Max as an upgrade but I have since read posts that they are not compatible. I have received my new hub and everything is connected and seems to be working fine. Can anyone confirm if they are compatible?
Re: Sky Q with WiFi Max
@Shanzo1 Do you only have a main Q box if so that should be fine
it's multiscreen that causes the problems so unless i am wrong  then if you have multiscreen the the Sky Max router causes problems
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@Shanzo1
Sky won't offer Max to addresses where there's a Q Multiscreen subscription with Mini boxes or Q boosters loaned to solve television issues.
This message was authored by: Sparkymatt100
@TimmyBGood
I'm confused about your last comment. I have Sky Q and a mini box and when I check for broadband upgrades,  MySky tells me I'm on the fastest speed available for my adress (superfast), but will offer me the new WIFI max modem upgrade.
Surely they most know I have a minibox. So why offer me wifi max of they are incompatible 🤷‍♂️
LG OLED65C3 65" 4K HDR TV
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 500
Avatar for Shanzo1
Yes I have multi screen, main box and a mini box.
Avatar for Shanzo1
I have multi screen and they have offered and supplied the new router.
@Sparkymatt100 wrote:
@TimmyBGood
As far as we're away that would be an error, but perhaps the situation has changed: when Max was launched it wasn't offered to Q households at all.
This message was authored by: bemak187
Assuming that the Max router has ditched the legacy mesh tech from Q.  In that case would likely work but essentially treat the router as "non sky" since there is no mesh, possibly?
This message was authored by: mitchell_paul_5
I contacted Sky yesterday with a view to ordering WiFi Max.  Sky customer services informed me that because I have Sky Q and 1x mini box, WiFi Max we not compatible.  He as very helpful and raised an internal ticket with engineering.  Today he contacted me to say that the engineer had confirmed that WiFi Mac was not compatible.
I'm using Sky WIFI Max with Sky Q. Q box connected by WiFi using sky broadband setting,  but I think it only connects on 2.4Ghz. Mini box also connected via wps to Q box with same router SSID.
Sky Q 2Tb HDR
Mini Box
Sky Full Fibre 500
@mitchell_paul_5 you should be able to get the max router with 1 mini box but if you have 2 or more there is still a problem so Sky are not providing the max router at the moment to anyone that has 2 or more mini boxes.
The advisors you spoke to may be confused between the 1 and 2 minis
@Laing1 , thank you for the confirmation.
Is it possible a Sky employee can confirm the same?
I guess I could call Sky again, but the last call lasted over an hour.  If I can't get it ressolved I will move to an alternative Broadband provider as this Sky Hub I currently have is not great.
This message was authored by: Pete4321a
I have 2 mini boxes Does anyone know if the main q box and 1 of the minis have wired connections that the problem is overcome?
@Pete4321a you can now have the max router and 2 mini boxes now the restiction has been lifted on it only being 1 mini box
