Discussion topic: Sky Q upgrade
This message was authored by: SpeedyTrip
Sky Q upgrade
I have just taken advantage of the Free upgrade to Sky Q, however, the girl on the phone said that an engineer would not be making the installation. Is the new box sent by Mail and a simple plug-in-and-go?
I have just read that my dish will require some changes?
Any advice gratefully received, thanks.
Re: Sky Q upgrade
@SpeedyTrip
You are correct. An engineer will be required to change the LNB on your satellite dish. The engineer should bring the Sky Q box, remotes, and any mini boxes you may have ordered.
Re: Sky Q upgrade
Very strange - an upgrade from SKY +/HD to SKY does indeed need an engineer visit to change the LNB(the electronic bit on the dish)
You may wish to read some notes I have made for people considering switching from SKY +/HD to SKY Q
SKY +/HD to SKY Q
