2
This discussion topic has been answered Discussion topic: Sky Q update fault
This message was authored by: eddski
Sky Q update fault
Sky Q box will not register it has been updated and the update page constantly appears. A system reset does not solve the fault.
This message was authored by: nigea99 Answer
Re: Sky Q update fault
hi @eddski
Is the Message you are seeing definitely from the mini - could it be an update to your TVs firmware & thus needs the TVs remote to clear ?
Perhaps you could post a screenshot of the message if trying the TV remote doesn't clear it
hi @eddski
Avatar for eddski
Thanks, it was the TV, not the Sky Q box.
