Discussion topic: Sky Fibre Sky WiFi Max and Sky Q Mini
This message was authored by: Adele+Andrews
For a long time, I had a very stable connection at home. I had sky broadband superfast and broadband boost. I had sky Q in a main living room and a sky Q mini box in a second living room.
Last week I upgraded to sky fibre 300 and just noticed that when working from home upstairs teams calls were a little bit glitchy. Sky Q boxes were working fine.
I have now upgraded to Sky Wi-Fi Max as from yesterday. I have noticed that the Sky Q mini box in my second sitting room does not connect. When it does it only works for about 30 seconds. I am thinking of going back to my broadband superfast broadband boost. Can anyone help. Thank you.
Re: Sky Fibre Sky WiFi Max and Sky Q Mini
Hi @Adele+Andrews
Reboot the mini as above.
