Discussion topic: Sky Q reset pin
Message posted on 01 Jan 2024 04:59 PM
Sky Q reset pin
Hi all, for some reason my pin got my sky q is not working today, I thought I'd reset it to change it anyway for the new year. If I enter my last 4 digits of my account it's saying incorrect which isn't true.. Can anyone advise as no idea what's going on with it
Message posted on 01 Jan 2024 05:09 PM
Re: Sky Q reset pin
Have you tried Sky's help here: https://www.sky.com/help/articles/your-pin-sky-q
Message posted on 01 Jan 2024 05:11 PM
Re: Sky Q reset pin
Yep no luck with the help guide
Message posted on 01 Jan 2024 05:54 PM
Re: Sky Q reset pin
@Kazmataz123 on Q the pin is usually the last 4 digits of your viewing card worth trying that ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 01 Jan 2024 06:52 PM
Re: Sky Q reset pin
Yep but I changed that number years ago I've managed to do it now anyway. Apparantly all I needed to go onto website and change it there. So all sorted now.. Thanks for help
