2
This discussion topic has been answered Discussion topic: Sky Q remote
This message was authored by: Sanmig+Queen
Sky Q remote
My Sky Q remote won't turn my Panasonic tv on or off. Panasonic engineer said is a Sky fault. It used to work now it doesn't. Even with a new reprogrammed remote. I've restarted & reprogrammed both , but still nothing. It's annoying having to use 2 remotes just for turning the tv on & off. Especially it worked fine for years until recently.
This message was authored by: Angel_Aka Answer
Re: Sky Q remote
What is the model number of your Panasonic TV? Many cheaper Panasonic models are actually made by Vestel so you could try pairing your remote to a Vestel code and see if it works.
Re: Sky Q remote
Avatar for Sanmig+Queen
Re: Sky Q remote
Panasonic TX-55, 2 years old. I'll try your suggestion thanks.
