Discussion topic: No network connection
Message posted on 11 Aug 2026 12:30 PM
Hi ~ no network connection on Sky TV have tried the reset and WPS button connection. External issue with Internet last week which Open Reach fixed ~ issue has been on and off since then also poor wifi and dropping connection although all lights are on on booster.
Message posted on 11 Aug 2026 02:45 PM
Re: No network connection
Hi @Vid2026
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
